My new 340
Discussion in 'Small Block Mopar Engine' started by gtsdude, Jul 16, 2017.
  1. gtsdude
    gtsdude Well-Known Member
    724
    107
    Jan 10, 2010
    SE MN
    Local Time:
    8:33 AM
    Thought I would share some pics of the parts car 73 340 4 speed charger with a 71 340 I bought last month at an auction. Not an A body but I bought it just for the 340 and I finally pulled the motor out last week, car was stored inside and the engine still has coolant so hopefully all is good with it. I have already broke even parting out the car, had no title, so if engine is not any good I am not out any cash, but the car has brand new headers on it that have never been fired, all the paint is still on them. It looks like someone was trying to get the car on the road. Has an A833 4 speed overdrive trans out of mid 80's truck and a limited slip 8 3/4 rear 323 rear. I am going to keep the entire drive train for now, never know what I might come across to throw it all into.
    • Like Like x 4
    • gtsdude
      724
      107
      Jan 10, 2010
      SE MN
      Local Time:
      8:33 AM
      • Like Like x 3
      • Abodybomber
        Abodybomber Breaking street machines , since 1983.....:)
        29,494
        7985
        May 21, 2011
        Arroyo grande ca
        Local Time:
        6:33 AM
        Best of luck, man... I would seriously be considering a diaphragm clutch over, what's hanging off that flywheel....
      • pink340swinger
        pink340swinger Well-Known Member
        66
        3
        Feb 6, 2008
        west middlesex, pa
        Local Time:
        8:33 AM
        are you sure it's a 1971 motor? just looking at the color it could be a 1970 or older 340. Can you post the casting date on the drivers side of the block, and vin number that is stamped on the passenger side oil pan rail please. Someone may be looking for their original motor.
      • 75Sport
        75Sport Grandpa
        1,039
        98
        Apr 22, 2010
        Michigan
        Local Time:
        8:33 AM
        I bet your van squatted under that load. Dan
        • Like Like x 1
        • gtsdude
          724
          107
          Jan 10, 2010
          SE MN
          Local Time:
          8:33 AM
          I'll get a pic of the vin #, I believe casting is oct 70, I'll grab a pic of that too.
          • Disagree Disagree x 1
          • gtsdude
            724
            107
            Jan 10, 2010
            SE MN
            Local Time:
            8:33 AM
            You could say that lol! I just need to haul it across the yard to my dads shop, I wanted to see if I could get it in my van.
          • gtsdude
            724
            107
            Jan 10, 2010
            SE MN
            Local Time:
            8:33 AM
            Here is the VIN off the block
          • gtsdude
            724
            107
            Jan 10, 2010
            SE MN
            Local Time:
            8:33 AM
            Casting date
          • gtsdude
            724
            107
            Jan 10, 2010
            SE MN
            Local Time:
            8:33 AM
            I pulled both heads and intake, J heads have 202 intake valves, stock bore with stock pistons still in it. With 2 pistons on each side installed backwards, notches to the rear. I'll have to get more pics.
