found ...need a timing cover 1975 225 slant six
oldrdggus
dodge 225
pa
in need of a timing cover 1975 225 slant six thanks gus
in need of a timing cover 1975 225 slant six also a harmonic blancer nut thanks gus
Welcome to FABO! Probably get a response on the cover here , but the parts wanted forum is the correct place to post this. Also there is no "balancer nut" or
bolt, the balancer(really just damper, the engine is neutral balanced), is a press-fit hub,...the threads in the crank are for using the installation tool to press
the damper on.
the damper on.
thanks seen that after i posted and could not delete it thanks and thank you oh and whitepunkonnitro already emailed me has one !
