olddog12
I have a 318/727 with points. Ive done some searching on here and did some checking and here is what I have found. BTW, all the wiring is original but has been taken apart or completely gone through. I am very electrically challenged also so please speak as if you were teaching your 10 year old lol.
Something that is odd...when I turn the key from run position back to auxiliary, the spark plug I have laying on the manifold would spark once a nice blue spark, did that three time with the key and cant repeat now??
Anyway I found this from 67dart273 in another thread and here is what Ive got so far.
1....Must have power to the coil when cranking. "Rig" your meter to the coil+ and watch the meter while cranking the engine USE THE KEY to do so, do not jumper the starter relay. You should have within a couple of tenths of a volt as 'same as battery.'. So after you read the coil+ / cranking, measure at the battery terminals. You want at least 10V or more
coil + side is 9.00 and battery is 12.58
2....You have "sort of" determined the coil is good, as you switched the coil
3....If you do NOT have voltage to the coil, you can simply jumper a clip lead to a batterysource, like the alternator output stud. DO NOT leave this hooked up longer than needed, you can damage the points and even the coil
is 9.00 v enough?
4...After you get 1---3 above, determine if the points are conducting when closed, and opening. Turn the key to "run." Bump the engine round until the points are CLOSED. Measure both coil+ and coil --. You should have very LOW voltage at coil neg, and about 6--9 at coil POS
coil + is 10.30
coil -- is .535
If you have this,.......
Bump the engine until the points are visibly open, and re-check. You should have "battery" at BOTH coil NEG and at coil POS
here im getting coil + 10.4 and coil -- is 1.30. Battery at 12.30
If you have this, chance the internal condenser (capacitor) inside the distributor.
Any suggestions on what to do next?
is 9.00 v enough?
coil + is 10.30
coil -- is .535
