Oil pressure gauge not working in Duster rally gauges
mistreta
Putting everything back together after having the bezel restored. Got just about everything working, new LED's bulbs, sockets, all gauges seem to be working except the oil pressure gauge.
At first it was pegged to the high side, along with the gas gauge, but once the whole thing was grounded the gas gauge is OK but now the oil pressure gauge does not move. I have a mechanical oil pressure gauge also that is on a fitting with the oil sending unit, I have good pressure. Could the problem be in the round plug with the connectors that plugs into the back of the dash? Does one of the wires make the oil pressure gauge work?
You just have to got through it..........
Circuit is pressure switch..........through bulkhead connector...........to cluster connector.......cluster pin.........trace..........to sender side of gauge STUD.........through gauge.....out other gauge STUD..........trace over to IVR
The only thing you know for sure is the IVR works because the other two gauges work
Start by grounding the oil sender wire/ key on. This should produce "full scale" on the gauge. Loosen/ tighten the stud nuts a few times.
Now, check for voltage from the IVR at both gauge studs both with sender wire grounded, and with sender wire open. Open should show IVR voltage on both gauge studs, grounded, the sender stud should be close to zero. If not, you have a problem in the connector pins/ wire/ bulkhead connector/ sender connector
If this seems to be, turn key off, unhook the cluster connector and "ohm" the sender wire to ground. Should be zero, with sender wire grounded in engine bay. This checks sender connector, bulkhead connector, and up to cluster connector
If that is OK check resistance from cluster pin to gauge stud, carefully, and do "wiggle test" for loose pin
Thank you
