wanahemi
Weird electrical problem happened today while taking my 68' Dart around. First noticed my factory amp gauge pegging the 'D' side in rhythm with the turn signal on in left position. Flasher clicking but no light on dash or on fender. Turned it off, then on again (left) and saw my aftermarket voltmeter had a major draw up and down also with the rhythm of the flasher. Saw a whisp of white smoke from the steering column. Made it home without turn signals & found out no brake or parking lights either. Found fuse popped. Replaced fuse. Tested parking lights, ok. Pressed brake pedal, pop, fuse blew. Not sure if I have one short or a couple. Will pull steering wheel to check the turn signal switch.
