Power to manual steering swap
Discussion in 'Suspension, Steering and Chassis' started by dropshot1, Oct 12, 2017.
  1. dropshot1
    dropshot1 Well-Known Member
    48
    20
    Nov 1, 2015
    stoney creek
    Local Time:
    11:06 AM
    Can anyone help me with the process and tell me what parts i would need to switch from power to manual steering, my car is a 70 dart 340 4spd, and im looking at putting headers on it.
  2. PST
    PST Marketing Manager FABO Vendor
    684
    118
    Apr 22, 2009
    Montville, NJ
    Local Time:
    11:06 AM
    You will need the manual steering box and the column adapter as the column is shorter on the power steering cars and possible the pitman arm. What ratio manual box are you looking at? We offer a 16:1 or 24:1
    Thanks
    James From
    PST
  3. 318willrun
    318willrun Stomper 4x4... we kept energizer in business FABO Gold Member
    5,272
    2470
    Sep 13, 2013
    I'm here
    Local Time:
    10:06 AM
    Manual steering box with the right pitman arm. Steering box can be from multiple cars including Dusters, Darts, Chargers, Satellites etc etc.
    You'll either need the adapter (new 117 from ebay), a manual steering column, or lock a grip pliers on your current column and pound it down. Manual steering columns were shorter from the factory. That should wrap it up
  4. dano
    dano Evil Handy Man
    2,071
    186
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    8:06 AM
    I run Doug's headers, PS and 4/5 speed (int he middle of a TKO swap, still z-bars operated) and used a Flaming River tilt column to clear the header tubes. It cost more but allows you to retain the PS and not beat the header tube, jack the motor up or shim the steering box, non of which I wanted to do. Some use just a U-joint, but that defeats the slider built into the factor coupler.
  5. pauly
    pauly MOPAR or no car!
    1,287
    102
    Nov 1, 2012
    Holton, Michigan
    Local Time:
    10:06 AM
    I have a manual steering box for sale in the classifieds. Would be interested in your power steering pump setup if you want to part with it.
  6. Veryfastdart
    Veryfastdart FABO Gold Member FABO Gold Member
    356
    53
    Feb 28, 2010
    Hampton NH
    Local Time:
    11:06 AM
    pauly
    Your inbox is full.
    I have a set up for sale.
  7. dropshot1
    48
    20
    Nov 1, 2015
    stoney creek
    Local Time:
    11:06 AM
    Do you have to pull the steering column or can you do it all from engine compartment, aswell do you reccomend changing the coupler and does anybody know what the factory steering ratio is? Thanks for all the help everybody
  8. RedFish
    RedFish Well-Known Member
    21,808
    1173
    Sep 5, 2007
    Local Time:
    11:06 AM
    You'll have to unbolt the column to separate it from the steering gear. There a lot of details in a recent thread. Sorry I don't have it book marked.
  9. PST
    684
    118
    Apr 22, 2009
    Montville, NJ
    Local Time:
    11:06 AM
    Factory Ratio was 24:1 for manual but they offered an optional 16:1 that was normally found in the A Body Barracuda with 383.
  10. 318willrun
    5,272
    2470
    Sep 13, 2013
    I'm here
    Local Time:
    10:06 AM
    Pretty straight forward. Drive the car on ramps. Yes, you'll unbolt the steering column under the dash, just unhook the gear selector rod if it's column shift. Remove drivers side manifold. Remove the battery and battery "holder" or "mount" stand. You'll need a pickle fork and a 3 lb hammer to break the pitman arm free from the steering linkage. I remove the pump, hoses, box all at once from the top.
    I've done this a few times, including just recently. Not a bad job at all.
  11. dropshot1
    48
    20
    Nov 1, 2015
    stoney creek
    Local Time:
    11:06 AM
    thanks so much
