rayer: I really need some help. I broke down Monday and had to be towed. I've searched the Dakota forums and can't find the answers. I'm sure there is someone here that knows the answers. Transfer case is cracked/exploded but the trans is ok.
My 2002 Dak has AT and 4.7. I have Thursday/Friday off to get this fixed. This is my primary transportation and I really need to get it back on the road.
Can I swap my AWD T/C for a regular T/C and what parts do I need?
Does the T/C have to be from a donor with a 4.7?
Will the swap stop the front drive shaft spinning? This is the 3rd drive shaft I've broken. Rancho suspension lift and 35 tires with 4.56 gears.
Anything else I need to know or I'll call you and discuss if better for you. Just PM me with a number and when. Thanks Craig
