Question for 1969 A57 code CUDA stripe
Cmekallm
Member
Florida
hi does anyone have any specs on the lower body treatment application on my A57 code CUDA? I want to paint it on and would like to know the width of the stripe just above the lower body accent and where to put the stripe on the lower part of the car. Also the hood stripe treatment, width and placement. Any help would be greatly appreciated
Are you concerned about the gloss level of the factory stripe vs paint?
I'm just curious, I know that doesn't help with your question.
I think I've seen ChallengerGary (who makess very nice stripe kits) give that info out before. If not, you could probably PM our Phoenix Graphic member.
Passenger side.
The drivers had a repair on the door so they may have re applied it incorrectly
The passenger side is factory applied
I won't be able to as. No longer have access to that car,
. BUT, if you look at the penastar and use it as guage I think you could almost figure it out within a mm or 1/16 of inch?
Can you measure the night of the stripe from bottom up, the space and also the width of the narrow stripe
Ok thanks, that gives me something to work with
CHALLENGERGARY might have a paint mask. Its worth the try
