Sixteen Barrel Cross Ram Intake
6X2 on my 440
That is fancy! Bet it has crisp throttle response being that the carb is over the intake port like that.
You know, I think that air horn, though fitting to the build of the intake, will shroud your air flow. I had a vaguely similar setup on a 4 barrel once, just an elbow (was going to make a cold air intake type deal), totally dogged and bogged simply with the elbow, exchanged the elbow for a regular breather, ran great. Not sure if that applies to your sweet intake setup.
I was thinking about building a long ram with four 2 barrels or something until I read that tuning a long ram really only gives power in 1 or 2 specific rpm points, and yields marginal to no advantage otherwise over a good normal intake...
Hey, what is that intake setup you have? Offenhauser? I would love to have that with a big breather that was like a dual quad breather, but covered all the carbs hooked to a super stock hood scoop.. :) yeaaaaaa! Well I guess your setup is more for a "rod" or "rat rod" type deal where you can see the carbs sucking air..
6X2 on my 440
