[SOLD] SOLD: Plymouth Barracuda 67 Taillight Assemblies - Used
soonercruiser
Oklahoma City, OK
Rating - 0%
0   0   0
Used Barracuda taillight assemblies in good-fair condition (Left & Right set)
Good enough for day drivers
These were incorrectly placed on the rear of my 67, with also the incorrect trunk trim. So, I'm not sure of the year application.
But the inserts are smaller than the 68 trim.
See here...
Mild to moderate pitting - following pictures are from all sides of the trim.
Right/passenger side is in good shape.
Driver's side (closeup picture) has more pitting and very small chip at the bottom of the lens.
Rubber seals are intact
Part numbers 2906793, 2606792 or 29838, 29839
$150 OBO, plus shipping, continental US
Location Oklahoma City
If you look on the lens itself there will be "SAE" and other letters and numbers in there will be 67 or 69
Yes that looks like a 1969 panel, it is the same height as the trunk lid. 1967 use a 3 piece trim as in 4spdragtop picture.
Yes, It looked like someone attempted a custom setup. They painted the 68 upper and lower trim red (instead of argent), and painted the center of the exposed lid black. That wouldn't really have worked with the correct 68 taillights because the red would have aligned with the white lenses, and the black would have aligned with the red lens. You probably need to start over to make it look right, with the 67 lights and proper 67 trim.
I think we visited this before with this same car. He may have a 68 decklid. When the 2 68 trim pieces are removed I would expect there might be holes in the wrong places just to install the 2 thin top and bottom trim pieces that should be on a 67. It would be great if he lucked out and could just remove the 2 he has and install the 3 correct ones. The pictures of the rest of the car look quite nice and a beautiful color.
Yes we've been thru it before with the op. Not sure why he wants to sell these tail lights? I wanted him to be aware he has correct ones for 67.
You are correct.
I had posted that we welded in the extra 68 mounting holes, and I DIY grinded, bondoed , and painted the trunk rear between the upper and lower trunk tril strips.
All that is a done deal!
The op is selling 67 lights, we wanted to make sure he knew he had 67 lights. There was an earlier thread from the op regarding trunk trim and tail lights, so the op being a fabo newbie I didn't want to see him make a "mistake". Some here are to help, some are here to buy and some are here to sell......
Soooooo...what was the purpose of All the inputs to help out on this post?
