Manual is such a drag in parking lots and to parralell park. I have flactory steering and a factory wheel. Moving is fine.Stay with the manual! I have factory PS, and it is a bit sloppy. I have replaced the PS pump and the PS steering box. I also completely rebuilt the front suspension. Still a bit sloppy. I have been told, many times, that it tended to be like that. Maybe not, but that is what I was told.
Thanks for the info. Did you change the whole shaft inside or separate it and just do the bottom? Will it still collapse in an accident?I went manual to a Firmfeel stage 2. Especially with the 4 speed I’d do it again. 14 inch Grant steering wheel. I got a p/s shaft from someone here and put that in my column so had the coupler. Someone here may trade or sell one cheap. Pump and other stuff from rockauto. Brackets from somewhere, not hard to find.
I did the whole shaft. Someone had one complete with the coupler, was not collapsed so just like from the factory. I also put a bearing at the bottom of the column since it was apart. Thread on that here somewhere.Thanks for the info. Did you change the whole shaft inside or separate it and just do the bottom? Will it still collapse in an accident?
OK, so theres a little snap ring above a bearing at the upper end of the column. Remove the snap ring, clean away any rust and burr at the snap ring groove. Entire shaft slides right out the bottom.Yea, I found a guy with a remanufactured gearbox,pump,pitman ,arm, and so way bar for a good price. I have the manual steering now. I'm sure I'll have to get a shorter shaft,and a p.s.coupler somewhere. Plus I'll need to find bolt on or weld on tabs for the sway bar now. Column has to be a manual tranny type because my 67 is auto with a console.
How much? Need anything other than bearings? Thanks.Do what you want, it's your car. I ditch manual for power Firm Feel Stage 3. Manual sucks. Do you have headers? Others outlined what you need. I have a power steering column shaft and coupler if you want to properly swap out the column shaft from manual to power.
I've seen that electric steering. Not sure if I trust its relialibility? Not sure how to swap it in either... Looks like a good idea though. Saves space under hood.what about the electric assist units?
Not quite strong arm manual, not quite water bed feeling factory power..
$35 Electric Power Steering with Fail-Safe - No eBay module and no caster issues!!!
InterestedThis is just the shaft that goes in your column. You take your column apart and replace the manual shaft with the power one.
Interested in your power steering steering colosjafy if you still have it. Let me know.
Bill
Ok, thanks for letting me know. Merry ChristmasSorry I just sold it.
