The "Black Menace" is pretty forlorn, LOL
Discussion in 'Members Restorations' started by 67Dart273, Nov 1, 2013.
  1. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:)
    29,294
    7750
    May 21, 2011
    Arroyo grande ca
    Local Time:
    9:38 AM
    Relax for a moment,Del....
  2. 67Dart273
    67Dart273 Well-Known Member
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Question..........anybody ever weld the two seams between the quarters and trunk / rear window?
    I think one of these is what was leaking, and what with the blaster having removed some of the seal, "we" were contemplating just welding and filling them?
  3. RustyRatRod
    RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
    43,776
    7039
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    12:38 PM
    Are you talking about the sail panel seam?
  4. tqfastfish
    tqfastfish "let the big fish eat"
    5,745
    81
    Jul 9, 2012
    GEORGIA VT
    Local Time:
    12:38 PM
    looking nice, Overall it does not look all that bad... other then the rocker. keep it going!
  5. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Ya got me. The two seams up flat on the rear deck about 8" long, that go for/ aftt from the rear window to the trunk.
  6. iw378
    iw378 Well-Known Member
    784
    96
    Sep 15, 2013
    Suisun City, Ca
    Local Time:
    9:38 AM
    I can't see a problem with welding them up. Your talking about where the upper quarter meets the member that fits between the decklid and the rear window??
    I wouldn't go full mig on it, rather just a small root pass tig welded to seal it and then filler over it.
  7. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    That's it. We were thinking of stitching them up to eliminate the need for sealer for watertight. "A little putty" to finish off
    I've also decided to remove the beltline molding (This is a GT) so I've got a bunch of holes to weld. In the next few days I'm gonna start practicing. I can weld to an extent, but thin stuff is my downfall. Thinking of using nails!!!! for backup material, just stick them through from the back, tack, and grind off the stems.
  8. iw378
    784
    96
    Sep 15, 2013
    Suisun City, Ca
    Local Time:
    9:38 AM
    That should work. Just a little advice on the welding. I don't know what kind of machine you are gonna use so here's my input. Mig (if you don't have a tig)
    A small 110 machine is good for this (lincoln or miller) small copperclad mig wire .025 and gas mix of 75/25,(runs cleaner than co2) As far as the nails go for backing, hit the heads on the bench grinder to get rid of any kind of coating like galvanizing and such.
    That will eliminate any blowouts. Pm me if you wish
    Luke
  9. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Thanks. My neighbor is pretty checked out. I'll probably leave those seams to him.
  10. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Some progress. Bear in mind my neighbor works full time, and wants his share of winter sports--sledding, mostly. So this like many is a "part time" deal. I'm no bodyman, LOL
    Some of the ongoing rust fixes. I bought lower quarter patches, for the damage in them
    On a side note, the flash I used on my Canon 7D is an ancient, Vivitar 285HV. Don' need 'no steenking fancy modern strobes, LOL
  11. RustyRatRod
    43,776
    7039
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    12:38 PM
    Refresh my memory. What are you going to use for power? A 273? It needs more.
  12. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    What's was in there is a stock block/ heads smog 318, mild little cam, and Holley EFI. What MAY go back in is a mild 360. I would love to put a single turbo on it, remains to be seen.
    The 273, which needed rebuild hasn't been in there for a very long time. The 360 came out of a van I junked, ran great for awhile, and developed a low end knock. I bought the 318, very low miles, for 200 bucks. I don't think it had 20K on it.
    The object was to get it going and have some fun vice having it torn down for months. The 318 turned out to be quite snotty. It's weak point is the TF which has a big 'ol low stall converter
    The 318 was fun to drive what with 3.7X rear gear, reverse manual TF.
  13. RustyRatRod
    43,776
    7039
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    12:38 PM
    I bet that was quite snappy. I put my vote in for a turbo 360 with a Thermoquad. lol
  14. txstang84
    txstang84 Well-Known Member
    4,307
    285
    Oct 10, 2011
    Abilene, TX
    Local Time:
    7:38 AM
    I'm likin' what you're doing here Del-can't wait to see more!
  15. clhyer
    clhyer Well-Known Member
    3,812
    240
    Feb 24, 2007
    Local Time:
    12:38 PM
    Looks very good so far. Tell the neighbor that you have a lot of friends here looking for regular weekly updates - with pics!
    Do you have your part of the deal done yet?
    C
  16. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Still have to install the OD unit for the AC later this spring. That will be a "wait for better weather" type deal. I get to buy the paint / materials
  17. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Decided to propose a change in wheels already. Unfortunately these are the "wrong" ones but I'm going with them, anyhow, Looks like I'll need a 1/2" spacer on the rear. Part of this is because I'm running a Versailles 9" rear, which is a bit wider than a Dart rear.
    I already have the front / rear stud situation worked out. These are the "later" wheels and have a different offset from the rears (the black ones), which were a "bolt on."
    The photo of the Dart is late this summer---14" ETs on the front, 17" Stang wheels on the back
  18. Abodybomber
    29,294
    7750
    May 21, 2011
    Arroyo grande ca
    Local Time:
    9:38 AM
    That would be unique, and a hell of,a tuning curve. For pure badasserrary,hands down.
  19. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Well I won't be running a Tquad. I already have way too much LOL invested in EFI
    the TB on my Holley EFI, even if I stay with TBI instead of coverting to multiport, already flows more than a TQ.
  20. daredevil
    daredevil Well-Known Member
    12,107
    145
    May 19, 2007
    S/w Houston
    View My Photos
    Local Time:
    11:38 AM
    I have seen many cars where these disappeared. Looks better in my opinion.
  21. txstang84
    4,307
    285
    Oct 10, 2011
    Abilene, TX
    Local Time:
    7:38 AM
    Those look like the first gen Bullitt style wheels...17"x8", should be with a 5.72" backspace--even with the wider axle, you still need spacers, or is it to keep the wheels off the springs?
  22. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    The black ones on the rear are early, the grey ones are the late. The late ones have deeper, "incorrect" backspace. See my update here:
    Some guy "on the www" claims you can tell by looking at the valve stems. The early ones "cut in" to the polished outer rim, IE are further "out." The late ones have the stems inside the polished outer rim
    http://www.forabodiesonly.com/mopar/showthread.php?t=237684
    The black ones fit mine, because of the Versailles axle I use, with no spacers. The grey ones will require 1/2" spacer, I may go with 3/4"
    The early, black ones are about 5 3/4" backspace, the late, grey ones have about 6 3/8
  23. txstang84
    4,307
    285
    Oct 10, 2011
    Abilene, TX
    Local Time:
    7:38 AM
    Oh wow, that's a pretty significant difference. I couldn't really tell by looking at the pictures, but I know the S-197 wheels are indeed a deeper backspace.
  24. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Not much to report. The neighbor finally announced tonight that "snowmobile season is over" so maybe I can kick his ass into gear. I had actually hoped we'd be further along He's welded up most of the chrome mountings, and got most of the work done on the lower quarter patches, and we've got the front /rear glass out. I pulled the dash frame out, finally
    I got the new short block, pulled the roller cam, and got it shipped to "Oregon cam grinders" who's going to turn it into a semblence of an XE -268H
    My old 71 340 X heads are out at a semi retired head shop guy in Post falls. This is just basic head work. I can't afford fancy porting, and don't want really high compression
    I'm thinking seriously........and probably will..........end up sticking the engine up in from the bottom, what with the new Dougs.
  25. 67Dart273
    34,863
    3074
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    9:38 AM
    Not much to update. I wish I could get some progress going. Also, I'm VERY lame this year. My new Doc is getting a hit for gout, and has me on a new med, and too early to see any result, yay or nay. Pulled the car out of the neighbor's shop last two days, and blew out as much blast media as I can get, and vacuumed it out. I can only work for a few minutes at a time, and have to sit and rest. Not sure how I'm really going to fully clean the cowl area. I bent some tube up in there, but there's still some in there
    The body IS pretty straight and much of the welding is done. I've decided to remove the GT chrome, and that is all welded up The lower quarter patches are "roughed" in but not done. Rockers are likewise not finish patched, but getting there. There is no serious body work left
    Got the cam back from Oregon cam. Have not got the heads back yet. Nothing special there, just a valve job.
