Rockauto has many photos. Often differs between AC and non-AC cars in the same year. Your radiator might not be original, so a P.O. may have changed hoses from original to match. I think all Mopars have 1.5" upper hose, which is true of most vehicles (exc. really small engines). The lower hose is 1.75" on my SB & BB and 1.5" on my slant six. Hot rodders customize hoses all the time, so you should never be hopeless. They often buy an F150 upper hose since cheap, long, w/ many bends and cut it to rotate w/ an aluminum splice which can also serve for a temp sensor, filter screen, tap for an oil cooler, etc. That is cleaner than the quick fix which is an ugly universal bellows type hose.
