I recently replaced the engine mounts on my Slant Six and learned a few things the hard way.
The old rubber was worn. So I ordered new inserts from Polybusings.com. The mounts have four components.
I then got smart and fixed my bashed oval sleeve and then took the other mount and burned out the rubber.
After doing some cleaning, it looked pretty nice.
Here it is installed!
Hope you found this helpful.
- The steel mount itself
- The oval metal sleeve that sits in an oval hole
- The rubber bushing/insert that goes inside the metal oval sleeve
- Another smaller metal sleeve that sits inside of the rubber bushing
