Torsion Bars
68 bee
ny
Will the torsion bars from a 1965 barracuda interchange with a 1969 Dart
Yes, are they both 6 cyl cars? There are different size diameter
for different weight engines etc.
http://www.moparmusclemagazine.com/...sion_bar_restoration_and_detailing/index.html
'71-and-earlier Torsion Bar Identification Chart
Right Hex Preset
Part Chart or Color Length Dia. Across Angle
Number Number Left Code (in.) (in.) Flats (deg.)
1857774 1857771 Right Orange 41.0 0.860 1.25 30°
775 1857771 Left Orange 41.0 0.860 1.25 30°
776 1857771 Right Green 41.0 0.880 1.25 30°
777 1857771 Left Green 41.0 0.880 1.25 30°
778 1857771 Right Aluminum 41.0 0.900 1.25 30°
779 1857771 Left Aluminum 41.0 0.900 1.25 30°
780 1857771 Right Brown 41.0 0.920 1.25 30°
781 1857771 Left Brown 41.0 0.920 1.25 30°
2269574 2269571 Right Orange 44.0 0.940 1.41 40°
575 2269571 Left Orange 44.0 0.940 1.41 40°
578 2269571 Right Brown 44.0 0.960 1.41 40°
579 2269571 Left Brown 44.0 0.960 1.41 40°
2269618 2269611 Right Yellow 47.0 0.940 1.41 44°
619 2269611 Left Yellow 47.0 0.940 1.41 44°
620 2269611 Right Aluminum 47.0 0.960 1.41 44°
621 2269611 Left Aluminum 47.0 0.960 1.41 44°
622 2269611 Right Olive 47.0 0.980 1.41 44°
623 2269611 Left Olive 47.0 0.980 1.41 44°
2535512 2535501 Right Brown 50.0 1.020 1.41 44°
513 2535501 Left Brown 50.0 1.020 1.41 44°
516 2535501 Right Blue 50.0 1.060 1.41 42°
517 2535501 Left Blue 50.0 1.060 1.41 42°
2535888 2535887 Right Yellow 35.8 0.830 1.25 30°
889 2535501 Left Yellow 35.8 0.830 1.25 30°
890 2535501 Right Olive 35.8 0.850 1.25 30°
891 2535501 Left Olive 35.8 0.850 1.25 30°
892 2535501 Right Blue 35.8 0.870 1.25 30°
Note: Chrysler originally put this chart together in 1971 as part of a service managers technical bulletin. It was not intended for reproduction or publication. It was confidential, for use by service department employees to identify parts in the field by their original color codes. It covers '71-and-older vehicles, but does not list every torsion bar.
Today, it is a valuable restoration tool. Roger Gibson uses it. He says it is accurate for muscle Mopars.
Acknowledgement:
Special thanks to Roger Gibson, Gibson Auto Restoration, Dept. MPRM, 106 State Highway PP, Scott City, Missouri 63780; 573-264-2022 for shop time to assemble the pictures and facts for this article.
Yes, Abody to Abody, 1963-76 :)
If you do, try to use matched pairs so the stiffnesses stay about the same. Mixing and matching can cause handling problems. If this is a circle track car.....nevermind!
The Barracuda has a 273 and the dart has a 340 would the torsion bars be the same part number. What other parts interchange, Suspension, Steering ? Would the frame rails or inner fenders swap?
the 340 torsion bars would be the slightly stiffer ones,
and would be a good upgrade, if you want a stiffer ride. :)
inner fenders are different,
frame rails are a maybe,
steering tie-rods tie-rod ends etc,would be larger on the 69,
but are also heavier duty, you of course would have to measure
and adjust them tie-rods to make the same length., end to end.
steering boxes interchange, brakes swap,
http://users.erols.com/dmapes/TECHNOTE.HTM
MOPAR A-BODY T-BAR
RATES AND APPLICATIONS
OD Wheel
Rate Application(s)
0.810" 82 Lb/In SLANT 6/DRAG RACING
0.870" 109 Lb/In SMALL BLOCK V8/STREET/DRAG RACING
0.890" 120 Lb/In BIG BLOCK/STREET/DRAG RACING
0.920" 137 Lb/In PERFORMANCE STREET
0.990" 184 Lb/In PERFORMANCE STREET/SOLO/TRACK DAY
1.040" 224 Lb/In PERFORMANCE STREET/SOLO/TRACK DAY/ROAD RACING
1.090" 270 Lb/In SOLO/TRACK DAY/ROAD RACING/OVAL TRACK
1.120" 305 Lb/In SOLO/TRACK DAY/ROAD RACING/OVAL TRACK
1.140" 323 Lb/In SOLO/HD-ROAD RACING/OVAL TRACK
1.180" 380 Lb/In SOLO/HD-ROAD RACING/OVAL TRACK
1.200" 396 Lb/In HD-SOLO/HD-ROAD RACING/HD-OVAL TRACK
1.240" 452 Lb/In HD-SOLO/HD-ROAD RACING/HD-OVAL TRACK
http://www.autorust.com/2008cat.pdf
They could have the same number but more important is the stiffness you desire. Check the numbers on the end of the bars and compare them to the above chart. The inner fenders and frame rails are different. Suspension interchanges. The steering gear will swap but the other steering components are different. Snag that 8 3/4 and leaf springs out of the 340 car and put that into the '65 too.
Thanks for the information. Im parting out the 65 barracuda and saving what I can to put on the 69 dart. I can upgrade to power steering on the 69, would I have to change the pitman arm?
Oh, I thought you were going the other way 'round. The pitman arm off the '69 manual box will fit the '65 power box. It's debateable as to whether that's an upgrade or not! You'll have to find a '67-9 A-body power column to do the swap though....or just the center shaft w/coupler out of a '68-9.
