lhearold
1969 Dart GT. Has been completely stripped and redone. No rust, all glass good, needs to be completed. Was appraised a little over 2 years ago for around $28k. Will dig up appraisal docs. Clear title. Was originally a /6. Now has a magnum based 408 stroker with EFI, A518 tranny built by Martin Saine. 8-3/4 sure-grip with 3:23 gears. 11.75 front disk, manual brakes, Firmfeel stage 3 power steering. LCA, UCA, and struts are all Firmfeel. 0.92 t-bars. Roll cage, sub-frame connectors. All glass good, dark tint in rear. Needs the speedo replaced (Auto Meter electric, failed after only 800 miles but over 2 years since purchase so no warranty), carpeting and center console. Needs the left dash vent hose run for the AC and also te lines from the firewall to the compressor, etc. Also needs the electronics completed for automatically shifting the OD and TC lock (have all parts). Nice on the highway, about 2000 RPM at 72 MPH in OD with the TC locked but will burn the tires off in all 3 gears. Still has a few loose ends to tie up but is at least 90% complete. Have extra parts that go with it. Located in Leominster, MA. Asking $7000.00
More pics to follow.
