HELP...I need a set of Duster Wheels
HowardBishop
Bishop, California
Hi Mopar Team....
I have stock steel wheels and radial white-wall tires on my 1972 Gold Duster. It has a 318 with disc brakes. The look needs help. I'm looking for a set of used Ralley Wheels or a set of used mags. It has small bolt pattern , 5-lug wheels, with small axles. I bought 235X60X14 raised letter tires. Now.....for the wheels......
Thanks
i have a like new set of crager s/s 14 inch rims. 425.00 shipped to you for the set
Thanks...it is a good driver....I bought it from the original owner...52,000 miles. Never been out of our county. Yep...she was a little old lady who worked at my school. I chased the car for 18 years before I got it from her. She is gone now but her car keeps cruising. The Edelbrock aluminum 4 bbl intake and 650 Holley Carb really woke it up...this week is dual exhausts.
Wow....nice job on the wheels....Makes me re-think the wheels. How do you think the 235's will fit on the stock wheels.????
all i had to do was sand blast them and use an exopy primer/sealer... never rust and hard as nails!
if you get some 5.5 or 6" wides they will... these were 4.5 i think, just little fronts...
Thanks for the wheel advice....and the tire counsel. This kind of help is so valuable to get before mistakes are made. Much appreciated.
if you also just go into summit and type in 235-60-15 or what ever, click a tire and it will give you rim suggested size and what not...
