Anybody running a 360 tunnel ram on the street?
Badart
Senior Member
Northern Utah
I am debating. I have a chance to pick a 360 tunnel ram on a parts trade. I have always wanted to run dual quads sticking out to the hood. :toothy7: My 360 is done as soon as I pick up my heads from the machine shop. I planned on running a Eddy RPM and a 750 that I already have, but this might be too tempting. What carbs would you guys recommend? How would the street manners be? This will be a weekend cruiser and make the occasional trip to the track.
Here is my combo
Zero deck 360 shooting for 10:1 CR
KB107 .030" over
Stock rods and crank
Comp XE275HL
J heads 2.02 1.60 (mild porting and bowl blending by my engine builder)
1.6 roller rockers
904 with TF-2 and 3K stall convertor
3.91 gears with detroit locker
This is what it would be going into.
Depends on which tunnel ram.
340 8bbl is pretty sharp on getting a TR to run on the street. Just takes time sorting them out.
Even though i'm not an eddy fan, I think a pair of 500s would work good once dialed in.
I sure enjoy my 340 with 2 600 vac. secondary holleys on eddy street tunnel ram. I will have to give crackedback a ride so he can give his opinion.
Here is mine, its a little work to drive on the street with 2 600's.
[ame="http://www.youtube.com/watch?v=sQolotFcSBA&feature=BFa&list=FLl8uIwMLgTNA&index=44"]‪TunnelRammed‬‏ - YouTube[/ame]
I've had an Eddy Street Tunnel Ram on the street since 2005
The smaller plenum helps a ton with a street car - the larger the plenum, the less velocity you have at lower rpm's
My Combo :
360 - std bore
kb 107's for a 9.4:1 comp ratio
stock 1978 small valve heads ( with air injection ports taped and plugged)
mopar p4452992 cam ( 474 lift 280 adv duration ( 230 ish)
stamped rockers
904
dynamic 9.5" converter
3.23 gears
The car has over 8000 miles on the street / strip with the setup - I've driven it in the rain( with a cover over the scoop )
never had any issues !
I started out buying the holley 450's - once i got them out of the box I returned them!
They had a mechanical secondary but no accelerator pump for them, it seemed like it was goung to be bog city - and in talking over the years with others who went that route, it in fact was a PIA with the design.
I rent with a set of holley 390's ( vac secondary setup)
I needed a holley balance tube to connect the secondary canisters together, to make them open at the same time :
My best pass was a 1.74 60' - 12.56 best ET, and 108 best mph.
with a ported 4 bbl intake and a holley 780 the best it would do was 1.84 60' - 13.20 @102
the T-ram made power everywhere for my setup.
I can get 16 mpg with the setup as long as I took it easy...lol
Last year I went with a pair of EZ EFI dual throttle bodies :
Talk about sweet! I gained 21 hp on the dyno, and have all the benifits of a modern efi system
Here is a before and after vid of the car running with the carbs and efi :
CARBS :
EFI :
http://youtu.be/JE8czQHBiqU?hd=1
That looks and sounds awesome.
I don't known thou, I think you should had played around more with the carbs. Carbs make more hp, they respond better to a/f ratio changes over f.i.
I know, 80% of folks think f.i is better but not 100%
carbs get a ram effect, that is were they can out hp a f.i. Those 390 carbs are very small, how much cfm is the f.i. units?
the efi units are 1000 CFM a piece - my take on it is that the carbs were my bottle neck, but awesome for the street - the EFI units are the nest of both worlds - more hp from teh added CFM and no off idle issues like a set of large carbs would have.
http://youtu.be/0C4Iy0QLKxE?hd=1
Tunnel Ram.....I wouldn't.....Oh wait I did....Love the old school through the hood look :glasses7:
Rickster
Dodgefreak- Nice!
How do you have the o2 sensors?
I thought about adapting a crossfire style 2 TBI setup and having the 02 for one in one header and one in the other.
I know that's cheating because one side would tune one throttle body/injector set, but the factory let one side tune the whole system a lot of times.
Here is my combo
KB107 .030" over
Comp XE275HL
1.6 roller rockers
Did you ever end up putting this combo together? I have a very similar build in mind and an edelbrock TR1Y sitting on the shelf
