Subject: 61 Lancer.. I am getting some 10" front brakes. Can the 9" front brakes with the spindle. Can the Lancer brakes be swapped out?
Did that swap on a 62 valiant, take everything between the knuckles from the 10" set-up ,swap it for the 9" set-up. Get the correct rubber lines & adjust & go, Lawrence
'62 and up would be no problem but I don't think it's a straight bolt-on for the '60-1 models.Did that swap on a 62 valiant, take everything between the knuckles from the 10" set-up ,swap it for the 9" set-up. Get the correct rubber lines & adjust & go, Lawrence
