seabee
Any advice on milling an aluminum intake (Edelbrock Performer). The heads got milled and now the bolts won't line up. Is there a certain way to measure it?
In some cases you can file the bolt holes with a round file if it is very close. use a thinner gasket I have done this with good results.Try and install it with no gaskets and see if it fits correctly. If so then get it milled the thickness of the gaskets. If you look around over on summitracing.com there are a lot of different thickness intake gaskets out there.
