1974 Dart Sport being parted out in PA
dpmalibu
Hatboro,PA
Just like title says. I am parting out a 1974 Dodge Dart Sport. Body had 77,000 original miles. Here is a list of the parts for sale:
1) Body shell Good for clear NJ title and ViN tag $200 (Nothing left on car. No suspension) You will need a Flatbed or a trailer with a winch to haul body away) Car is located in Hamilton,NJ (Trenton area)
2) Doors Both solid. No rust $175 ea.
3) trunk lid $80
4) tailights $40
5) gas tank filler tube $25
6) rear bumper w/ bumper shocks (needs to be rechromed) $40
7) Complete wiring harness from engine compartment to trunk area $40.
8) Complete seat belt set (black) $40
9) rear seat $30
10) 1/4 panel glass $50pr.
11) tinted windsheild $100
12) rear glass $100
13) Misc stainless trim $40 for the lot
14) Rear u-bolts w/ shock bracket $20
15) radiator (in good shape but I would get it reconditioned) $20
16) (4) stock steel 14" wheels (3) big bolt pattern (4.5") and (1) small bolt pattern (4")
17) brand new leaf springs $125
18) Power front disc brake setup spindles, rotors,calipers,upper control arm, Power booster/master cylinder $150
19) lower control arms $30pr,
20) torsion bars they are in like new condition but are 15-17 years old. Were put on car and car was not driven after that $75
Found more stuff:
original winshield wiper arms $25 pr.
bumper fillers $20 pr.
fan shroud $25
tail light bezels (pitted) $25 for all 4
Lower Prices:
2) Doors Both solid. No rust $125 ea.
3) trunk lid $60
4) tailights $40
8) rear seat $30
9) 1/4 panel glass $50pr.
10) tinted windsheild $80
11) rear glass $80
12) Misc stainless trim $40 for the lot
13) HVAC parts I have the whole system. prices vary
15) Rear u-bolts w/ shock bracket $20
16) radiator (in good shape but I would get it reconditioned) $20
17) (4) stock steel 14" wheels (3) big bolt pattern (4.5") and (1) small bolt pattern (4") $20 ea.
19) power front disc brake set up ( upper control arms, spindles, rotors,calipers, brake booster/mastercylinder $125
20) lower control arms $30pr.
22) wiper arms $25
23) bumper fillers $25pr.
24) V8 fan shroud $30
I have to check. not sure it was all pulled off when I started taking it apart. i will let you know.
Do you still have the bumper absorbers? I need all if you have them. Also can you post or pm me a picture of them? I'll have to make sure they're the right kind. Thanks
Ok thanks. I'll get back to you soon on those. Was it just the rear ones? Also do u have the left front fender? Pictures if you do please? Thanks
More stuff taken off car today:
(1) Cragar SS black spokes . has some surface rust has a tire on it but not good $25
Tail light panel/section (cut off back of car) $125
(1) rear side marker light $10
original bumper jack w/ lug wrench/jack handle $25
gas cap $10
trans crossmember $15
Glass is in very good shape. Came off a 77k mile car. Car sat in garage last 12 years. hasn't been driven in probably 17 years if not longer than that.
1) Body shell Good for clear NJ title and ViN tag $150 (Nothing left on car. No suspension) You will need a Flatbed or a trailer with a winch to haul body away) Car is located in Hamilton,NJ (Trenton area)
2) Doors Both solid. No rust $100 ea.
3) trunk lid $50
4) gas tank filler tube $20
5) rear bumper w/ bumper shocks (needs to be rechromed) $30
6)rear seat $30
7) 1/4 panel glass $40pr.
8) tinted windsheild $75
9) rear glass $75
10) Misc stainless trim $40 for the lot
11) radiator (in good shape but I would get it reconditioned) $20
12) (4) stock steel 14" wheels (3) big bolt pattern (4.5") and (1) small bolt pattern (4") $20 ea.
13) lower control arms $30pr.
14) wiper arms $25
15) bumper fillers $25pr.
16) (1) Cragar SS black spokes . has some surface rust has a tire on it but not good $25
17)Tail light panel/section (cut off back of car) $125
18) (1) rear side marker light $10
19) original bumper jack w/ lug wrench/jack handle $25
20) gas cap $10
21) trans crossmember $15
I probably have it but I don't know what the pieces look like since they were pulled off the car already when I started parting it out. I have a pile of stainless trim for the car. I wnat $40 for everything.
I sent a PM for the overflow tank with my confirm to buy air shocks. Also I,m interested in the disk brakes and related parts What is the bolt pattern? I need 5 0n 4" thanks Jim
