Thermoquad fuel return line
71duster06
West Michigan (GR)
Does anyone have a fuel return line set up for a Thermoquad or any single inlet carb? I have seen a lot of return line setups for Holley's or other dual feed carbs but i was curious what you guys run.
Run the return line from the pressure regulator before the carb
or if you don't use a regulator, use a fuel filter with built in orifice
Wix 33040/ 41 are 5/16 and 3/8 filters,
33054 is 5/16 with a 90* orifice
