mopowers
What gauge is the fusible link from the starter relay to the ammeter on a 68 Dart??? I'm guessing it's 16g???
Where did that diagram come from?? It shows 16g whereas two other guys said to use 14g. Does it matter at that point??? I s it better to be safe than sorry?
thats the MAD ammeter bypass diagram. i recently did this to my duster and added a volt gauge. i bypassed the bulkhead connectors as well.
here is the whole artical
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
yes, that article lays it out for you, but ran mine through another existing hole with a grommet instead of through the connector.How do you bypass the bulkhead connector? Just pass the wire through one of the slots without using a conector?
