OK, it's out of hibernation!!! Running/driving down the road, REAL A56 340 'cuda, 4speed, EXPORT ORDER(Y09)car? I've never seen another one! B5 blue, black buckets/head rests, console 4spd. Dash tag, fender tag, rad support, trunk lip, MOTOR, TRANS ALL MATCH. Very unmolested under the hood. Original carb, dual pt dist, 066 rad, air cleaner, exhaust manifolds, EXPORT ORDER tag, ect. I have the bottom half of the build sheet starting with the A codes showing A56. Has one of the nicest rear finish panels i've seen on an original car. Optional dash with 150 speedo, tach and trip odometer.
The car was likely redone in the '80s with the typical exterior resto and stripes painted on. Believed to be in CT most of it's life, now in NY. Will need the typical resto eventually. It was at Carlisle in the time bandits category in 2011.
PM Q's $13,800. FIRM, NO TRADES
