I got to checking for a solution to the fuel drain back problem. I found this on the internet. It came from the UK. it is a one way valve. I bought the 3/8" one to put in the fuel line inlet just before the carb. I will let you know if it works.
I'm betting that if you check the flow through that, you'll be disappointed.
I think as long as you can push 5-6 psi of fuel pressure through it , it should workwell, I don't know about the flow. I blew through it one way and it was wide open. I blew the opposite way and it is blocked. I will let you know. You know as much as I do about it. But had to start somewhere.
you know what I meant LOL. its a 3/8 hole and im sure it doesn't squeeze down to a 1/32 inch hole LOLPressure is secondary, as GPM is the important one.
You can get 150 lbs through a needle sized line, but it isn't going to supply the volume needed.
I'm sure you know that already though.
67 ,seen the return line article, Mopar Action years ago. It works,slick.
xs2you need to put the valve before the pump. this will keep the pump primed and will not allow it to drain...
