4 speed bellhousings?
70DusterGuy
Member
Adair, Oklahoma
I have an A-833 4 speed tranny with the 4.35'' retainer bearing. What would happen if i used the bellhousing that has the larger retainer bearing hole?
Do you know of those fit the Lakewood bells??
I believe it will, my Lakewood came with a spacer and fits the one tranny I have perfectly, the other tranny I have has the larger bearing retainer and it doesn't need the spacer.
Pm me the diameter of your bell housing and I'll try and measure mine before I bolt it back together.
You can also replace the bearing retainer to get the right diameter for the bell housing. Go to the Brewers Performance site.
Oh ok thanks guys ill be ordering one.. What's the damages if one isn't used?? I didn't have one for a while
