I've now got all the fittings and hoses to run from the fuel tank to the engine. Bought Russell parts, but there are many other vendors. If I was doing it again, I would run hose from rear to front instead of using part of a 3/8" S/S line. The swage fittings from 3/8" tube to -6AN are very expensive. It is relatively easy to buy the hose and cut and add fittings on each end. The hoses I used are all teflon lined so I dont have any deterioration due to different fuels.
These are the parts I used starting from the fuel tank.
90 deg 1/4" NPT to -6AN male Russell 614106
12" -6AN female to -6AN female Hose Russell 658490
3/8" EFI female to -6AN male Russell 640850
5/16" EFI female to -6AN male Russell 640860
WIX fuel filter/regulator Amazon 33737
3/8" EFI male to -6AN male Russell 640940
3/8" S/S tube to -6AN male fittings Pure Choice Motorsports 5770
3/8" S/S fuel line Fine Lines
24" -6AN female to -6AN female Hose Russell 658510
-6AN male to -6AN male coupler Russell 660350
Fuel line and gauge - passenger side Street & Performance
