Latest 408 from MRL Performance
MRL Performance
here
So here is our latest build. Thought you might like to see what it is and what it did.
360 prepped for a 408 stroker
SCAT 9000 4" crank
RPM H beam rods
Mahle flat top pistons
ProComp heads 2.02/1.60 exhaust port work only, and very little at that
Hughes roller rockers 1.5
Lunati SFT cam 251/259 duration
Old School Holley Strip Dominator
750 carb from some carb shop(customer supplied)
Kevco oil pan
MSD dist(customer supplied)
Well thats the basic run down
12 to 1 compression Like I said minor port work on these heads. Good valves, good valve job. Minor bowl work on the intake side to blend the new valve job into the bowls and NOTHING else on the intake side. Cleaned up the bowls on the exhaust and smoothed some small ridges and thats it.
Timing was 20* to start and 35* total at 3200rpm
Carb was not all that great and there was no real adjustment to it, so our A/F ratios were from 11.5 to 13.3. BSFC was .375 to .458, not to bad but could have been better.
It made 551HP at 5800rpm and 535TQ at 4700rpm
500+TQ from 3750-5800rpm. Actual torque peak was at 4700rpm but it made 530+ from 4200-5100rpm
500+HP from4950 rpm on up
I have to tell ya, these ProComp heads are nice. I have built and sent out 6 sets in the last 2 months. They flow better than the RPM and have a better, cleaner casting.
I have 3 more SBM with these heads going on the dyno this next month or 2 so stay tuned!
What's the price on a set of those heads done up like this dyno test?
Is that a OOTB Pro Comp,or CNC programming casting,I heard about? Nice numbers. Hated porting my crusty Eddy RPM's.Nice combo,like that solid flat tappet!
These are NON CNC ported. As cast with minor cleanup. I made 600HP with the CNC ported ones and the Voodoo SFT 1 size bigger cam in a pump gas 408 this past spring.
Price for these heads set up for a solid flat tappet, 2.02/1.60 is $1550. Chambers are 62cc.
That's awesome mike. I can't wait till I get all my stuff from u. Hope it's a beast like we have been talking about.
Jeremy
Looks like you've got another winner Mike. Great numbers. I would still like to see you do a 273. lol tmm
Nice numbers! what's the lobe separation on that camshaft?
How much more porting potential in the procomp do you suppose there is compared to the edelbrocks?
Also this is off topic but, skrews. that Dr. Evil "turbo" pic in your sig cracked me up big time. :lol:
The price is pretty good on the heads. Are you finding any delivery issues from the supplier?
110LSA They have a greater potential from what I have seen.
Nope, I get them direct
Ill do a 273 if someone orders one. Dont think it will ever happen, just like 383's or 318's, just no demand for them at all.
