[WANTED] need 1969 Dart rear brake drums
furyus2
weeki wachee fl
I'm looking for a pair of rear brake drums for a 69 Dart swinger 10" if you know where to find new ones for a good price, that would be great. Also interested in a good used pair. Located in Weeki Wachee FL 34613 Thanks.
I'm not looking for a
mopar repairman. I am looking for 10" rear drums for a 69 Dart. If you have them, and want to sell them, PM me.
I have used for 8 3/4 large 4 1/2" pattern and can get new for 4" lug spread. All for less than $30.00 each. Would need a little more info to get correct ones. David
If you can get 4" bolt pattern 10x1.75" drums for less than $30 each, there's going to be a lot of people who want to know about that.
Found a pair of drums on Amazon for less than $50. Will have them in 2 weeks will update then. Info didn't state if they were 4 or 4 1/2" bolt pattern, so I took a shot at it........
Probably 4 1/2" pattern. I'd bet on it. What was the part #? Should be easy enough to look up with a part number.
Well I test fit the drums, and at least they got the bolt pattern right. They are too wide. I had a friend cut 1/8" off of the lip and the edge for clearance. They fit, but the other thing is they are 2 piece drums. The face and the round braking surface are fused together somehow. Not welded. I would not recommend these.
advance auto parts has the rear drums 95.00 ea
My name is MOPAR CHARLIE, I am located in Holiday, Fl. I do MOPAR REPAIRS
727-271-5068
