Does anyone recognize this part???
So it's a 75ish small block A/C alternator bracket, Mopar right?? I have this as an extra part and want to sell it, but I needed to know the application. Anyone else???
Thanks,
Treblig
The mounting hole where it bolts to the head looks broken off. No bolt can pull it down evenly.
it's a big block alt.brkt.early 70's on up...it's also broke...as rob said...that half circle is where it bolts to the block/head is supposed to be a hole circle
Very Nice, Thanks for all the input. There's no way I could have figured it out by myself. I'm a machinist and a welder so I can easily fix the broken bolt hole. If the part is worth something to somebody I'll fix it otherwise it's back to the junk box
Treblig
