Was wondering anyone running a big block in an early A? What oil pan are you using. Didn't know if the 67 newer pans would work or some after market. Would like extra capacity. Schumacher says an Moroso pan would work.
Did you search, both here and on bigblockdart.com?
Doing some digging for you. Please hold as the Klein Techline finds your answer...
If I find nothing, PM abodyjoe. He had a 440 in an early A. He definitely would know what oil pan to use. Also pishta would probably know too
My apologies, I thought you were looking for anything. :violent1: I can't find anything on an aftermarket pan.Yes I asked Joe. He wasn't running anything special.
I'm interested in aftermarket pans with extra capacity.
Thanks for digging.
will try cfr 7117 oilpan when I get home in a couple of weeks will let you know 64 dart 496 BBops:
he is looking for an aftermarket hi-cap pan.I ran the 187 pan, nice big factory clearance where the idler arm goes. 699 or 669? same dealio.
