ok fella's for those of you interested, when i got my hemi denny kframe, i met Denny to pick it up. that is where my issue started. while Denny was going over the install , he told me the motor gets offset to the left 1.5, yes he said left... he followed that up by saying that will let the alternator clear the frame rail. so the entire time i was mocking up MMounts there was no way it was going to the left 1.5.
the trans was bolted in place, and to the motor,so i was satisfied with just getting it centered. now the mounts are finished and welded in place, the left rear corner of the VC hits the steering shaft.
being so focused on the steering shaft, i never even thought of the trans.
well come to find out that moving the motor to the left to get it centered in front, that cocked the trans . after taking out the trans mount bolts, the trans relcated itself to the right. that moved the back of the motor to the right. that let the VC clear the shaft.. now the motor is centered in the engine bay the trans is setting right of center. but everything fits, everything clears. and the drive shaft wont hit anything, and the universal will make up the offset in the drive line..
now i just have to mod the trans cross member...
