[SOLD] 1966 Plymouth Fury III Big Block
moparguy1967
Rating - 0%
0   0   0
New 446 Big Block built by Andy Jensen
Engine made 520HP and 560ftlb on the dyno
440 HP block 30 over
Forged Crank
Ross Forged Pistons 10.5 to 1
Scat H-Beam Rods
MP 284 / 528 solid lifter cam
Coyle Adjustable Double Roller Timing Set
906 Iron Heads Port work done by Andy Jensen
Larger Stainless Steel Valves
Crower Springs and Retainers
Crain Gold Roller Rockers with MP hold downs
Edlebrock RPM Performer Intake
950 CFM custom build Pro Systems 4150 HP
HP Manifolds with 2.5" full exhaust.
Freshly rebuild 727
Part kickdown throttle body
PTC 9.5" 3200-3500 stall converter
8.75 / 3.55 sure grip rear - Just serviced
New Fuel tank and 3/8" SS pick up/ sending unit
-6 Braided fuel lines and fittings from tank to carb.
Aluminum Radiator with Shroud and Dual Electric Fans
MP dual circuit master cylinder / Manual Brakes
New 60 amp Alternator
New Power Steering Pump and lines.
B&M Trans cooler with -6 Braided Lines from the trans to the cooler.
New Belts and Hoses
Less then 400 miles on all parts.
Plus so much more. . .. . .. . .. . .. . .. . .. . .
Open to Trade of equal value. . .. . .Lets talk.
$12500.00 obo
I almost for got...
Motor now has Stealth Alum Heads with Comp Cam Springs and Retainers.
Motor made 520hp and 560fttq with the iron 906 heads.
adding a video
[ame="http://www.youtube.com/watch?v=n5NweB9PyhU"]1966 Plymouth Fury III 440 - YouTube[/ame]
Sorry .... Sold.
It went to a guy outside Pittsburgh, PA. Its been 12.50s at 112mph. I wish i had not sold it.
