[WANTED] wtb a body 4 speed shifter rods.
I have a set from Classic Industries the reverse rod wont clear the trans mount
on my Demon I am researching to make sure I have the right mechanism and mounting tab ect I think they were $95
Classic Industries came with clips and bushings too bad they dont work. I think PG Classic get theirs from the same supplier
When I put in my new exhaust in with an x-pipe. The factory reverse rod wouldn't work. Went to the scrap yard and bought a straight rod and using my torch, bent it to fit and then welded a fine tooth bolt to the end and ground down the other to fit. Works perfect. Cost 75 cents.
I'll either find some used OEM ones or buy from brewers. So as of now I'm still looking for a set of rods and levers.
