Easiest, least expensive route is to find a '64-65 V8 cable shift trans, or at least the transmission case.
(Note: '64 was last year for push button shift, with '65 going to a column shift lever. However, the trans was still cable controlled in '65, just with the cables originating from the lower end of the steering column, or the floor shifter.
'66 was the first year for the "hard" linkage.)
Mike in FL
