Torsion bar rubber seals
rod7515
Red Lion PA
I need to find where I can buy the rubber seals that go on the front side of the torsion bar that covers the snap ring. I need to buy a pair and NAPA can not supply them. Was wondering what they are called and if anyone has a name of a supplier.
Thanks
Rod
They don't cover the snap ring btw. They go on between the LCA and the front of the torsion bar mounts. Covering the mount from the front The hole on the back of the torsion bar mount where the snap ring goes into should be filled with grease when done....per factory manual.
Good luck.
