Looking for 273
I have a may 65 rebuilt 273 charger motor I pulled from my 64 dart and stuffed in a 340.
I just pulled it and it is still fresh.
I have a 66 273/235 that's in the process of being rebuilt. Am about 80 miles west of DC.
I jumaulled it and it is still fresh.
What are asking for it? Is it complete, carb. and exhaust manifolds? Where are you located?
I am currently using the exhaust manifolds on the 340, I plan on using a set of dougs soon and I will have no need for them then.
I have a carter afb on it, but it isn't original to it and it need to be rejected.
You will need a water pump and a distributor.
It has an Offy intake and valve covers, I have a set of original charger valve covers if you want those instead.
I am in Orlando. Fl. and I was thinking 3500 for it, but I am willing to negotiate, there is way more than that in it.
I also have the 4 speed that came with it.
The only thing missing is the distributor and the water pump. I will have the exhaust manifolds soon other than that it is complete.
I can dig up a dissy and a water pump, but you prabably will want a new one for your build.
