It's been a while since I've had to troubleshoot a points system, but I did manage to get my 67 318 running a few months ago.
This time it's an unmolested 67 225 and it's kicking my ***!
The points were worn to the backing metal, so I replaced them and the condenser with new units out of the box.
Also replaced rotor.
The cap doesn't look bad, and I scraped the tower contacts with my fingernail to clear any corrosion.
I set the gap at .020 (middle of spec of .017-.023). Dwell read 8-10* on my meter.
I have 12v at the coil, and I've swapped out the coil twice, the last time from a running vehicle.
Also swapped out the coil wire twice, last time known good.
I have an adjustable gap type spark checker, and no matter what- no spark.
I could jump/replace the ballast, but if it were bad, wouldn't it start then stop when they key was released?
I thought about jumping the coil to hot, but I've got 12V there.
If I put the coil wire on the spark plug checker, should I get a spark? I got nuthin".
...and that's after three coils, the last one known good!
Seems like something is causing the distributor to fail at telling the coil to fire.
I'm about stumped.
I'm about stumped.
