fishy68
Tyr Fryr's Inc.
I was thinking about that as well, but could I just weld in some baffles or something? I was looking at a kevco pan, they have good ground clearance and a crank scraper, but I don't think it'll be very easy to get here, or cheap. I was also looking at milodon pans and the one I was looking at didn't have room for a windage tray.
And one reason I want oil pressure is because I am running a solid roller camshaft, my lifters have pressure oiling, but still want as much oil to them as I can.
Yes you could weld in some baffles in your stock pan. Be real careful cause the pan is thin and you can blow through it pretty easy. From what I've read a windage tray really isn't needed with a deep pan that has baffles.
