AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,608
- Reaction score
- 13,844
RRR;Thanks for the kind words.
I think SGbarracuda (post24)is on the right track,as are others.
However, I have a different theory.I am imagining a lifter with little to no oil in it.In this case the plunger is able to freely move throughout its operating range.So when the lifter is on the base circle,that little spring inside it takes up all the slack. Then as the lobe starts to raise the lifter, the pushrod just moves down into the lifter until it bottoms.Then finally, the lobe is able to transmit motion to the rocker arm, how-be-it, not very much. This is a theory.
Its pretty simple to prove. Put that lifter on the base circle, then just push down on the rocker arm.If Im right the rockerarm will easily move the pushrod down into the lifter.
If Im wrong and nothing moves,then the lifter is full, and its hooped.
You may be able to shine a lite down beside the pushrod tunnels and see the lobes, but I think the angle is wrong. However if you remove the rocker-shaft assy and the one p-rod, you may be able to fish the lifter out of the bore(they make a tool for that).Once the lifter is out, lobe/lifter inspection is easy. If the lifter wont come out of the bore, SGbarracuda probably nailed it and the bottom of it is wiped, and mushroomed.Then the intake needs to come off for further inspection.
And if the lobe/lifter is wiped, you know whatchagotta do.
I, among others,have gotten away with not doing a complete tear-down and thorough cleaning of the parts. I think thats poor practice. That/those lobes went into the oilpan.Nobody can say they ended up in the oilfilter, 100%. I got lucky, and have gotten another 100,000 miles out of my engine.
