so I re-placed the Ballast Resistor, Ignition relay , Power Relay, re-placed fuses in fuse box , can't find a fuse able link to battery...has electronic points ,caps good put new Spark plugs -gaped at 40....can Ark Jump start Starter and turns over stonge, put fresh gas in it but after 50-60 cranks not picking up gas to carb... still no power at dash or lights , also has a canister that's plumbed to water hoses that you can plug in '''' ..it works heats up quik......will keep looking for fuse able link....it doesn't have a 'condenser any were will get one tomorrow.....that's all it took on last car 72 Scamp
