My high-beams AND low-beams would work and switch back and forth with the floor mounted switch before I installed my headlight relay kit from crackedback.
But now I only have high-beams...if I step on the switch - the lights go off (low-beams "should" have come on).
Crackedback has been awesome and more than helpful and we checked his parts by jumping off the battery with a wire - his relays and harness all work perfect. I can get both high and low beams by jumping it.
He thinks I have a ground issue somewhere in my original system. Sounds reasonable to me.
I've looked and looked and can't seem to find it! ARG!!!!!
Any ideas or suggestions?
Thanks in advance!
:coffee2:
Thanks in advance!
:coffee2:
