LCA Brackets
sabre67
B.C. Canada
IM installing a Hotchkis front sway bar on my71 Duster,I need the end link brackets that weld onto LCA. Does anyone know who could supply them,or have a diagram and specs so I could get some made? Thanks ps Hotchkis does not sell them separately only supplied in complete kit.
Factory style sway bar tabs for the 65-72, lower control arms aren't repoped by anybody.
So you need to search out the aftermarket suspension vendors to see what they have for their own line of sway bars, or you fabricate, make, something yourself, and then weld them on.
Or in the far extreme, you find a pair of lower control arms with the factory tabs on them, rebuild them, then put them on the car.
yes I contacted Hotchkiss and they don't sell them separately,I thoughts some one hear may have gone through this before and knew of a suspension outfit to try. Thanks for your reply
They are soooo easy to build it's ridiculous.
Getting them welded or mounted on the LCA in the right place is the hard part.
MAN sometimes I wish I was closer to some of you guys, but then the Wife would always be wondering where the hell I was all the time. :D
