hardcore
Member
A good friend has a 66 B Body Charger, with a 1967 383. The heads are newly reconditioned 906 series. He bought the car cheap, and not running, although everything was intact. The original heads had valves rusted into the guides, so it sat for some time. I helped him get the old heads off, new heads on, checked the cam, and replaced the timing chain. Everything has been checked and rechecked mechanically; the engine has very good compression.
When he purchased the car, it came with a tunnel ram intake with two carter 650 cfm carbs. The car has an electric fuel pump and holds 12-15 psi fuel pressure. There is also an aftermarket electronic ignition with an accel performance coil. The cam is aftermarket and slightly hotter than stock. Everything seems to be operating as it should, except the car simply WILL NOT START.
I've checked the distributor installation three or four times; everything correctly on top dead center and the firing order is correct. There is fuel in the carbs and the fuel definitely sprays from the carbs' accelerator pumps. We almost had the thing fired a couple times, but it keeps popping back through the carbs. I would usually assume timing, but its been checked and rechecked, (TDC on compression stroke, timing mark on TDC, rotor pointing to number 1 plug, etc.)
Has anyone else experienced this problem? The only thing I can see possibly causing the problem is the spark looks a little weak. I don't know if the tunnel ram intake could cause hard starting...I've pulled the plugs but they aren't wet or fouled. Any help would be appreciated. Thanks.....
