I'm running 255-60-15 on the rear and 215-70-14 on the front
-- Torque Thrusts with the darker gray center are my favorites. ---- the second one is what it would look like with Torque Thrust wheels instead. --
SS wheels...
OK. So here is a photo of the wheel with the cap off. Can anyone tell me what the factory bolt pattern in on the 69 GTS? I measured, and the center of the stud (skipping one) is a shade under 4 inches. Is this a 5x4 pattern? YES
Is this the same as the B bodies????? I don't think so - only the A bodies had the 5x4 - in this era & Mopar
What you have on now is a 14x5.5" small bolt pattern rim! The widest tire "suggested" for that rim would be a 215mm, so you're already pushing it! There was just a set of Cragar SS rims and tires near me that the guy was running on his 69 Dart that were 14x8 in the back and 14x7 in the front, 3 3/8" backspace in the rear, with 265mm tires! I passed on them, shoulda bought them, they were $450 for the set including lug nuts and tires!!!
