nm9stheham
Yes, this is 2.8" tall and the Mancini unit is about 3.3" tall.
http://www.manciniracing.com/maracofanblk.html
Have you contacted them?
Sooo is it available? Anywhere? Thanks
Ben;
Hayden has a shorter fan clutch in development. We married the 2765 shaft to the 2747, but saw the need for a larger shaft mounting surface than what the 2765 offered. Since then we have tooled a new shaft and are working on producing units and releasing the data to our customers to in turn offer to the classic car crowd. There is no firm release date at this time as our engineering team wants to put the clutch through all of the appropriate life cycle testing.
Thanks.
Donald Harrison
Product Analyst/Specialist
SMP_Temp_sm
1801 Waters Ridge Dr.
Lewisville, TX 75057
972.316.8100 ext. 8227 hone
972.316.8213 :Fax
Donald.Harrison@smpcorp.com
have a link? the hayden ones i see on summits site say not for over 250 cubic inches..Derale, Flex-a-lite, and Hayden all sell steel 6-blade fans that'll bolt to that clutch.
i found ths one.. https://www.summitracing.com/parts/der-17117/reviews
I am using the 5 blade Mopar performance fan blade... this one has a huge PITCH
2.5 inch + together with a severe duty fan clutch this set up makes a Hurricane!
Never passing the 185 deg..... with a 180°F thermostat.... never
Greetings Juergen
Any luck finding new 5 blade fans?does any one sell the fan blade? it seems that they don't sell the viscous setup any more
