Sedanman
67-9 Valiant specialist
I found this car here (Valiantsurf) when I was looking for a set of fenders for my Signet. He was going to part it out so we swapped emails back and forth with pics and the fenders were NOS quality so I asked what the rest of the car looked like and he said rust free and straight so being the Valiant guy that I am bought it to keep it from being cut up for parts. It's a 67 Valiant 100 /6,auto,radio delete,manual mirrors with a/c and that was the only option it was ordered with and it is #81 off the assy line. He was going to make a drag car out of it with a BB and had already welded in the inboard spring kit into the frames and 1 frame tie in. It is pretty much a clean bare shell with no interior. I scored an a body dana 60 off CL,some springs, hangers at the Indy swap and I located a manual steering box and column. I have quite a stock of nice 67 grills,tail lights and other exterior chrome. I also picked up a 318/904 drivetrain from another member with some nice LA decor stuff and acc's I will need if I go small block.
I am thinking early 90's LA roller 360 block (need to locate core) with an A999 trans and the Dana with the top end TBD, I picked this one up because I can mod it how I want which I can't do to my Signet. I like the balance of a small block car and don't really want a nose heavy car and there is a butt load of aftermarket parts for LA motors still. I just got some pics from Surf telling me that the car is rolling and about ready for transport from CA to Chicago. I have no clue how quick this project will go since I am still working on the Signet's body so I will update as I go along. If I can get my Signet painted before this one comes home I will have this one in my garage at the house (1 car) and the Signet at my storage garage since it actually runs. I saw a fellow members' 67 Valiant that was painted satin black and I like it. It looks like a night stalker with minimal trim or I may go some sort of blue.
The first order of buisness with the 100 is blasting the shell
get it in primer
finish the back 1/2 of the inboard kit
get a suspension under it
gear change the dana from 4:88 to a streetable gear and add the inboard perches
widen the wheel wells
drill all of the clip holes for the 68-up front and rear trim
remove old drip rail sealer
change the blower motor opening to the non a/c style
and hopefully figure out the drivetrain combo with some of the parts I already have.
My mechanical parts stock so far is:
904
727
A999
MP valve covers,I do like stock 60's covers better
RPM Air Gap
MSD or factory electronic
small block pullies and alt brackets and acc's
Holley 3310
Holley 670
Holley street avenger 750
Demon 625 afb
drop base air cleaners for Carter and Holley
73-6 v8 k frame w/ sway bar and disc's
11 3/4 disc's
70-2 v8 a body radiator
488 dana 11x2.5 brakes
dana to 727 driveshaft,I have 3 others but unknown drivelines
shock plates
kyb rear shocks
TTI SB headers
340 windage tray no bolts
Manual steering box
floor shift column (ps)
column shift manual column
BP kickdown cable kit
trans mount
15x8 old school wheels and tires
VFN fiberglass hood,bolt on
6 pak scoop
That's all I can think of off the top of my head at the moment
My Signet resto thread:http://www.forabodiesonly.com/mopar/showthread.php?t=211139
get it in primer
904
727
A999
RPM Air Gap
Holley 3310
Holley 670
Demon 625 afb
11 3/4 disc's
shock plates
kyb rear shocks
TTI SB headers
Manual steering box
trans mount
6 pak scoop
