My 340 is running hot I think.. I need a sanity check.
Yep so I took it out for a ride and took some video along the way. The first video is of the start up and a walk around. IT seems like every time I start it I have water on the floor. It doesn't stain and smells like condensation. After I run it things dry up. Sorry for the crappy video.
The rest focus on the gauges a various time along the way.
One video gives a look down the throat of the carb after I stopped. I didn't see any wetness.
In one of the last sets you'll see that gauge go up to 230 at rest guessing no air flow would cause that.
Lastly it did gulp a few times and of course it did not fire right up. but as suggested I held the throttle down a little and it did start.
OK, well if it did help it to start hot by holding the throttle down some, then it is too rich at start, and by opening the throttle, it is leaning out the mixture. Was the camera shot down the carb immediately after a hot shutdown or a few minutes after?
If your initial timing was too much at hot start, the engine would turn over and then stop or kickback. That does not sound like your hot start symptom.....??
BTW, it was hard to tell in the 1st pix but was the exhaust on the ground after you backed out of the garage kinda sooty black? (Or was that just wet pavement?)
Camera shot down the carb was a few minutes after.
  • No it does not kick back or turn over and stop so I think we can check that off.
  • Didn't appear to be puddling or wetness in the intake either. Check that too.
  • Yes, holding the throttle down a bit helped get it started.
  • The top hose had pressure.
  • the cooling system did gulp a few times even once or twice after the car what shut down but nothing spewed out this time
Running Rich sounds like a step in the right direction I'll follow up on that at inspect the carb.
In the first video what you saw on the ground was moisture (wet asphalt driveway). That happens whenever I start the car for the first time but id dries up after a short while.
I have no black soot in the pipe I wiped it with a towel and the moisture on the ground smells like condensation and exhaust. The spot dries and leaves nothing behind.
190.. so whats the problem again? Get an overflow & call it a day.
I know that whats getting me. The gauges say I'm good. but the reactions from the engine are questionable.
I'll install an over flow to stop messing up the ground and hopefully address the gulping. But I still have trouble starting the car after it gets hot.
Actually, if it started better with the throttle held open some then DON'T pump the pedal before a hot start..... it'll just make it worse. I'd agree on a carb heat shield. Holley makes a composite one that sells for about $30 that is about 1/4" thick.
And OK OP on the ground condensation. Pretty normal, and the clean tailpipe sounds great; does not sound like anything is very rich at all. These cammed, carbed engines often will just not start like a modern fuel injected car so I would not consider the 'questionable'. My son's 340 starts better hot by holding the throttle open a bit. It uses a Holley 670 Street Avenger (4160 type).
BTW, OP what ignition system does your car have?
I was just reading a thread on the carb spacer and potential of fuel boiling... It was a pain in the *** setting up my Holley to work with my factory Linkage so the idea of adding thick spacer is not appealing although a 1/4 " deal seems doable.
My ignition is an MSD billet pro Dist., MSD 6A controller, blaster 2 coil and 8.5 mm Taylor wires with champion plugs. I gutted the Ballast resister and jumped it out by soldering in a piece of 10 gauge wire.
If there's enough bite on the intake bolts, just use washers/spacers under the brackets for the linkage. Also, despite what MSD says,
keep your plugs gapped at .035".
Do you have the stock or stock replacement metal hard line that runs down the chassis on the passenger side of the car? Is it continuous unbroken or repaired without repair joins in metal or rubber gas line?
Is the rubber flex gas line from the chassis gas line to the gas pickup and mechanical fuel pump new?
Do you have a picture without the air cleaner of the passenger side of the engine showing the fuel line from fuel pump to carb?
New 3/8 Stainless steel hardline continuous from back to front.
The rubber gas line at each end of the hardline is new.
The pickup, gas line and fuel pump are all new.
The fuel filter is in the suction side of the pump between the pump and the chassis line.
Pictures attached
Pictures attached
Is that braided line from the fuel pump to the carb touching the fuel pump body?
Might want to try some firesleeve insulation over the as much of the lines as possible. I even ran it around the hardline down the passenger frame rail.
I try to get the fuel lines as far as possible from any naturally heat holding metallic objects. I know this looks extreme with the line going around the alternator, but since it was a mini alternator it was more feasible. IMHO that area between the alternator, block, and timing chain surrounds the fuel line with heat sources.
attachment.php
Before:
attachment.php
autoX
Did you fab up that breather set-up? very nice.
Does that pan fit in the stock K?
Yes. thank you.
It fits the 67-72 k better.
The 73-76 which I run is very close. A added some reinforcements years ago that make it fit really close on the drivers side. If you are putting the motor in from the top, it needs to be motor only no trans connected.
autoX
thx. I have a 1970-K.
Are those late-style bypass hoses connecting the breather pipe to the covers? and what did you use right at the cover for nipples?
autoX
thx. I have a 70K.
Yep. Good eye. Saw them in an old Winston cup poster I have that shows detail shots of an old Petty car.
I bought those valve covers from guy that ran dirt track Mopars and the round tubes were already welded on. The bypass tubes fit perfect. I doubt a coincidence. Same cal custom valve cover with tubes in same place as the Petty car in the old poster. Maybe a kit car part?
Sick looking motor! Thanks for the advice. No the braided line is clear of the pump but touching the water pump. So we are starting to narrow this down to a fuel/heat related issue. At this point I think insulating the fuel line around the engine and double checking the carb settings makes sense.
Read my sig, down at the bottom.
The tendency for most of us with up-sized street-cams is to ram the timing into the engine as hard and fast as possible. You will hear things like time to the highest vacuum, or crank it in til the starter kicks back.While there's no denying that this can work, I don't subscribe to this ideology for streeters with less than 240*ish cams, and stockish TCs.
I subscribe to getting the T-port sync set up, and let the idle timing fall where it may.
-To get a nice idle, is a little trickier this way, but it eliminates a few harder to overcome issues,later.And granted, getting a custom timing curve is trickier as well.
To me a streeter needs a well-tuned Vcan. And with a very-fast, single-pattern curve, getting the Vcan to be of proper use, is a real challenge.
-Getting a fast mechanical curve to work with a stockish TC and sub-optimum gears is an exercise in frustration.Unless your Dynamic C/R is in the basement.
With a 2800TC and minimum 3.23s, or a stick car with 3.55s or better, the ram-it method can work if you are not much concerned with fuel-economy.
-So here's my philosophy. Ram-it is for race-cars. Streeters are gonna have to spend some time choreographing all 3 or 4 timing systems. 3 or 4? yes.
You know about Centrifugal advance, and you know about Vacuum advance.
The C-timing is used to compensate for the decreasing amount of time available to light the fire as rpm goes up, and
The V-timing is used to compensate for engine loading/cylinder inefficiency's at lower rpms and part throttle.
So what else; Well, additionally we have the rate of mechanical advance and the rate of vacuum advance and the amount of vacuum advance, and the vacuum advance cut-in point.And one of the most important is the rpm at which the centrifugal starts.
As far as I can tell a street engine has at least 5 timing requirements. They are full power, idle, part throttle, hiway, and PT-cruise.The only one the dyno can figure out is the power-timing, and sometimes they are not even the best at that.
It is on you to figure out the rest.And I gotta warn you, it can take thousands of miles and many months to get a sweet program.But take heart, you can get close enough to start driving in a couple of hours or so. After 2 or 3 days, you will begin to understand how all these systems interplay. And when the summer is almost over, you will have had the dizzy out so many times you will wish you hadda just rammed it.
So you wanna start with the idle timing, cuz if the engine won't idle reasonably well, it is very frustrating, and all other timing adjustments are relative to the idle set-up and the power set-up. The latter of which is generally fixed over a very narrow range.
So where to begin with idle timing?
Well the engine will idle with anywhere from about 5 to 25 degrees; the only compensations being throttle opening and idle mixture.
Problem #1), the more advance you give it, the less throttle it will want to control idle speed. This leads to
Problem #2),the further closed the throttle is, the less transfer is exposed. This can be compensated for, to a degree, with the mixture screws, but this leads to
Problem #3), hesitation at throttle tip-in.
-Now comes a a personal street preference; for power and economy, you need a big engine with a small cam and in-the basement gears. Since this philosophy is at odds with reason, some sacrifices have to be made to whit; rear gears,camming and engine size. Most of us have found that SBMs work pretty good with 3.55s,and sub 228* cams as DDs or sub 240*cams and as much as 4.30s(for the adventurous)as weekenders.And 5 gears trumps everything.
But what has this got to do with timing? Well if your stuck with 2.76s and 1400TC, your SBM will have completely different timing limitations than the guy with a 2800 and 4.30s; completely different. So if you subscribe to the ram-it theory, be prepared to change your rod bearings frequently, and eventually your skirts may fall into the pan.
Then we have
Problem #4). At hiway speed. In considering fuel economy, the engine will want a ton of advance, and as minuscule a throttle opening as possible. Here comes the T-port sync again. Yes it is entirely possible to have the engine wanting to be very low on the transfers to get the best economy possible.
-Back to the beginning; where to start with timing.
Having now an idea of what timing is needed under whatever your application might be, Just follow the outline below, and the engine will tell you what idle-timing it wants. How easy is that?
I guess I could have told you that on line 1. but would you have believed me? Probably not; it's too simple.
The truth is; Every combo is different. Any number a guy can ballpark is just that.
Your engine will tell you what it wants. Learning to listen, and being able to answer it, will make all the difference.
So why did I go there in post#63?
Well glad you asked. Retarded timing leads to overheat, and so does lean running.
Now I believe that excessively retarded timing leads to excessive throttle opening, and that coupled with overheat, usually leads to run-on after the ignition is killed. You didn't mention that. So Ima thinkin your engine is not excessively retarded.
I believe that excessive advance leads to very small low-speed throttle openings, which leads to lean-running.
So I wanna say; T-port sync.
But hey, until thr IR gun results are in , I could be pissing in the wind.....
185 is not even close to being hot running any cooler than that can cause premature engine ware among other things
Read my sig
Then we have
AJ very cool.. thank you! This is a very insightful and detailed follow up. I admit that I don't have a handle on all of it yet But I will get up to speed. You have given me a lot to chew on and get my head around. This is exactly the reason I got into the hobby.
Backing up the 340 is a 2400 stall and 3.91 gears
