Lets see those engine bays!!
MoparMcK
Canton, SD
I am currently building a 440 for my Demon. Would like to see the layouts you all have for the wiring, fuel line, etc.
Not done yet, but you get the gist...From the firewall, wiring goes 3 ways. Down Drivers fender and across front of radiator support, under intake manifold, or down....to starter. Worked on AC lines today....
440 GTS "BAD *** RIDE' not easy wiring to follow , nore is it a car you want to race , or you will be following lol
Here's the compartment a high 11 second '68 'vert that gets 18 mpg at 70mph on the freeway and 12-14 around town with an injected 408" Magnum, a lock-up overdrive and A/C.
Three pictures showing no electronics (regulator - solenoid - ECU etc) where did they go ????????????
I don't think the OP is getting the information he or she is looking for but some pretty nice stuff showing up
This is pretty much stock wiring. We were running a Pertronix at the time, so no need for a box.
