Anyone have a part # for seal and for a bearing for sb water pump? I would like to clean it up while its out.
For a 67 273 with ac.
Thanks
Steve
Thanks
Steve
Let me check the trash, I just threw out a cast iron water pump for a 68 318. It worked fine, no leaks. If the trash guy hasn't come by yet, you can have it for shipping from 95409. I think it's around 10 pounds.
No a/c, just power steeringThanks OM. Don't go dumpster diving,mine is fine. While mine is removed I planned on sandblasting and painting. Would be nice to replace bearing n seal while its off.
Thanks for the part offer.
Oh yours might be worth hanging onto if its for ac?
The rebuilders want that core. There isn't ample supply of cast iron water pump cores. If new are available they are surely Chinese.Let me check the trash, I just threw out a cast iron water pump for a 68 318. It worked fine, no leaks. If the trash guy hasn't come by yet, you can have it for shipping from 95409. I think it's around 10 pounds.
